Technika jizdy - Racing
935Baby
Příspěvek od 935Baby » 25.02.2007, 22:09
Jaksi jsem dnes objevil techniku projizdeni zatacek zvanou TRAIL BRAKING - v článku tučně zvýrazněná část. To jsem hlavne hledal protože by to nejak nebylo jasne.
Tak jsem si rikal ze jsem hodim cely tento clanek. Přecijenom o jízním stylu se to moc nemluví a dost čelnů zejdí blbnout na okruhy tak si myslím že téma Technika jizdy je docela dobrý nápad.
Most of the articles which we have featured in GRM's "Race Craft" columns the last few years have been evolutionary in nature. Starting with the more basic driving skills, we progressed quickly to more and more advanced techniques. While this may have worked well for those of you who are seasoned competitors and long-time subscribers, it is not so beneficial to new readers.
From time to time, it is important that we revisit basic driving techniques and address the most common basic driving mistakes. This article is not merely for the benefit of new readers, but for any reader who drives in competition or at speed. After all, good advanced driving skills are built upon a solid foundation of good basic driving techniques. Even if you are already a proficient competition driver, I am sure you will learn something of value as we examine the top 10 basic driving mistakes-and how to correct them.
Definition of Terms
Before we talk about the most common driving mistakes, we need to define the terms which we will use in this article. While the following terms apply more specifically to road race circuits, most also have relevance to autocross racing. (Note to autocrossers: You may wish to insert the words "pointer cone" or "lay down cone" where I use the word "cone," since autocross courses are frequently lined with hundreds of stand-up cones.)
Racing Line: The racing line is the fastest way around the track when no race traffic is present. At racing schools, a series of cones are placed around the track to teach students the ideal racing line. By connecting the dots between these cones, you will find the quickest way around the track. (See illustration at right: Line through an increasing radius corner.)
Braking Markers: Braking markers are generally marked with descending numbers such as 4, 3, 2, 1. These are references which tell a driver when to start braking and downshifting prior to entering a corner.
Turn-in Point: Turn-in (or turn-down) cones are the dots on the outside of a track which tell the driver, "This is when you should start turning into the apex of the corner." At this point you begin the arc of your corner.
Trail Braking: Trail braking is the technique of using light and gradually diminishing brake pressure to help steer your car toward the apex of the corner. Used after straight line braking.
Apex Point: Apex cones mark the inside point or geometric center of the corner. An early-apex cone generally indicates an increasing-radius corner or a corner which gets wider at the exit of the turn. A late-apex cone generally indicates a decreasing-radius corner or a corner which gets tighter towards the exit.
Track-out Point: Track-out cones mark the outside dot or extreme outside exit point of a corner as you come off an apex. These cones are located on the outside of the corner, and they often precede a straightaway.
Correct Line: By hitting your brake and downshift points properly and by connecting the dots from the turn-in cone to the apex cone to the track-out cone, you have the correct line through the corner and onto the straightaway. (See illustration below). Note: While most SCCA race courses will have brake markers, few tracks will have turn-in cones, apex cones or track-out cones. You are expected to find these points for yourself. The reference to "cones" in this article is simply used to facilitate the illustration of the proper line.
Understeer: If you continue to dial in more steering to get to the apex of the corner, but your car does not respond and just goes straight, this is understeer. Understeer is also called "push" or "plow."
Oversteer: As you turn into the apex of a corner, if the rear end of your car begins to break loose and travel faster than the front end of your car as you round the corner, this is oversteer. In oval track racing circles, oversteer is also known as "stepping out" or a "loose condition."
Top 10 Basic Driving Mistakes :
Mistake #1: Improper Driving Position
The proper driving position is important because it helps you get the optimal feedback from your car's chassis while also keeping you from getting fatigued.
First, your seat should be adjusted so that you are able to depress the clutch completely and perform heel/toe braking without banging your knee on the steering column. You should also be able to use the dead pedal for support through high-g turns. Your shoulder harness should be tight so that you do not need to rely upon the steering wheel for support.
Next, you should have a 90- to 120-degree bend in your elbows with your hands in the proper 3 and 9 o'clock positions on the steering wheel. This will allow you to make a 180-degree turn of the wheel when you need to correct an oversteer slide.
Ideally, your thumbs should be in contact with the 3 and 9 spokes on the steering wheel. This gives you more direct feedback from the front suspension in case of an understeer situation. (Note: Since formula car and sports racer steering wheels are smaller in diameter, your arms should be straighter and have less bend at the elbows).
Finally, your butt should be tucked firmly into the seat back so that you can get feedback from the chassis and up through the seat. This will give you a better feel as to what the rear end of the car is doing. In keeping with the Zen philosophy of racing, you should become one with your car. Get comfortable, go faster.
Mistake #2: Failure to Look Ahead
The most common driving mistake in both autocross and road racing is failure to look far enough ahead.
As street drivers, many of us become lazy and look only between the A pillars (those down posts which border the edges of our windshield). On a race track, because of the planning and high speeds involved, this will not get the job done. You must condition yourself not only to look much farther ahead, but out the left and right side windows as well.
Entering a corner, as you are doing your braking and downshifting, you must be looking ahead to the apex of the corner. Before you reach the apex, you should be looking ahead to your track-out point. In "S" turns, often you have to be looking ahead to the second apex, rather than the corner you are in. In this case, you must trust your peripheral vision to take care of the first apex.
The rule of thumb is, "The faster the car, the farther you must look ahead." The malady of "driving off your hood" is one that relegates many race drivers to slower cars while other competitors make the transition to higher powered cars with ease.
If you are limited in terms of track time, practice looking much farther ahead and out side windows as you negotiate off-ramps and corners on back roads. If looking ahead becomes habitual, you are much more likely to use the technique on the race track. And no, I am not advocating that you adjust your street driving speed upward to match your newfound, long-range vision. That ticket is on you.
Mistake #3: Improper Braking Technique
If you often brake too early for a corner, you may find that looking ahead will cure your problem. When you know where the apex and track-out points are located, it is much easier to know when to ease off the brake pedal and precisely how much to release it. However, you may have other braking problems which do not vanish so easily.
Some drivers brake hard enough in a straight line to slow their car down for the corner, but then they totally release the brake or go to the throttle before they get to the apex of the corner. They transfer the weight off the front tires and onto the rear wheels just when they need their steering the most. This can cause the car to go into an understeer skid. (Refer again to illustration on opposite page bottom.)
In order to keep the weight on the front and the tire contact patches expanded for optimal steering, you should use trail braking. Trail braking is simply continuing to apply a diminishing percentage of braking until you complete your turn into the apex. The transition from trail braking to the apex and the application of throttle to the track-out point should be smooth and seamless so as not to upset the chassis.
Mistake #4: Improper Downshift Technique
More correctly, this should be called "Improper Brake and Downshift Technique," since it is difficult to separate the two. I would like to explain the entire sequence of heel-and-toe braking and downshifting; that would be an article in itself, however, so I will not.
Simply put, the theory of the heel-and-toe downshift is this: When braking and downshifting prior to a corner, you must brake in a straight line while simultaneously clutching the car, revving the engine to match the speed of the drive wheels, putting the car into a lower gear and then releasing the clutch without upsetting the tire contact patches and suspension in the process.
For those of you who do not know how to heel-and-toe downshift, you may want to go to Bob Bondurant's or Skip Barber's driving schools. For those of you who know how to heel-and-toe downshift, but are still not doing it as smoothly as you would like (i.e.: you are chirping the tires when you downshift), here are a few tips:
· With your car in neutral and with the engine running, practice putting pressure on the brake pedal with the ball of your foot while swinging your heel and the outside of your foot over onto the gas pedal. Please, do not touch the shift lever!
· Using constant brake pedal pressure, try to rev the engine up to a reasonable rpm and hold it there. Repeat the process, pivoting your foot from left to right until you feel you can do this with consistent repeatability. Your tire chirping problem is probably due to your lack of revving your engine up high enough or blurping the throttle and downshifting too slowly.
· Practice your downshifts at your next autocross event or on an uninhabited back road. Better yet, take a refresher driving school course until you have your heel/toe downshift perfect. Good braking and downshifting is essential if you want to improve your lap times. (Not everyone, however, is impressed with a good heel/toe downshift technique. Mr. Holland, my high school driver education teacher, marked me off for doing it.)
Mistake #5: Apexing Too Early
On most race courses, there are far more late-apex corners than early-apex corners. So, if you want to be successful in autocross or road racing, you had better get used to learning how to drive late-apex corners. At driving schools, where cones mark the turn-in points, apexes and track-out points, you may not have a problem. But what about driving an unfamiliar track? For a better understanding of this problem, please refer to the illustration below.
There is an easy way to determine the location of the apex for a corner. Work backwards from the track-out point, to the apex, then to the turn-in point. Ideally, you want to exit the corner in as straight a line as possible. This will help you maintain momentum and maximize straightaway speed.
When dealing with more than one corner (See illustration below), where the last corner in the series leads onto a long straightaway, you must often sacrifice your entry speed into the first corner to get more exit speed off of the last corner. It is better to "go in slow and come out fast" when exiting onto a straight.
Apexing too early is the number one killer of straightaway momentum. The symptoms of apexing too early are as follows: You turn into the corner where you think the apex should be, but upon exiting the corner, you find that you need excessive steering input just to stay on the track. You have major understeer and you are scuffing off way too much speed at the track-out point as you exit the corner. Go back and study the line of this part of the track again. You may be apexing too early.
Mistake #6: Premature Acceleration
If you are not apexing too early, you may be suffering from premature acceleration. While embarrassing, premature acceleration is not a condition you have to live with forever. However, the cure does require patience and control.
It is not enough to brake and downshift properly and turn into the apex at the right point if you still are going to apply the throttle too early in a corner. Be patient. Trail brake long enough to get the nose of your car pointed at the apex and aligned with your track-out point. Why accelerate before you have the car pointed in the right direction? When you transition to throttle, do so smoothly without upsetting the chassis, but be ready to go to the throttle when you reach your last apex and the car is pointed down the straight.
Mistake #7: Not Using the Entire Track
If you watch professional F1 drivers, you will notice that they use every last inch of the race track, including the flat curbs. All too often I follow students who have great technique but who do not use the entire race track. This hurts their lap times tremendously. When asked, "Why aren't you using the whole track?" they usually respond with surprise, "I thought I was."
At some time during practice, you should touch the curbs slightly so that you know you are using the entire track. Next, you should find out which of the flat curbs will help or hurt your lap times. Racing is a game of inches. Inches become tenths of a second. A tenth of a second on each corner can turn into a full second per lap.
Mistake #8: Failure to Compensate for Slip Angles
Everyone knows that race cars slide or drift through corners, but not all race drivers completely understand the effects of slip angles or the direction of drift.
If you are braking, downshifting and turning into a corner correctly, but are still not near the apex, you may not be compensating for the slip angle of your car. Perhaps you are aiming for the apex cone, but you just cannot seem to hit it correctly.
The fix may be relatively easy. Aim behind the apex cone, imagining a "false" or "phantom" apex cone is there. By compensating for your car's slip angle, you will probably hit the apex precisely. This may take some experimentation as you may compensate too much or too little for the slip angle while finding your phantom apex.
Mistake #9: Killing your Momentum in Traffic
While this driving mistake does not apply to autocross racing, it is most definitely one of the most common and frustrating problems for inexperienced race drivers. Getting boxed in. Losing your momentum. Getting stuck behind a slower car. Being unable to pass for a lap or two. Does this sound familiar?
The best solution to this problem is early recognition of the slower driver. Notice where he is on the track now and where he most likely will be when you want to pass him. Depending on your race pace, you may either need to speed up or slow down to pass him at the point where your momentum will not be diminished dramatically.
You may have to hustle and out-brake the lapper before the next series of slow "S" turns, or you may have to lay back a little and build momentum off a turn to pass him on the next straightaway. This is perfecting the art of looking ahead to the max.
If you get extremely proficient at this technique, you can use it to strategically sandwich a car that you are passing between you and a car that is in hot pursuit of you. Not only can looking ahead be used to maintain your own momentum, but it can be used to kill someone else's momentum. When it works, it is truly a thing of beauty.
Mistake #10: Poor Weight Management
Small tire contact patches are all that keep you from leaving the track. The faster you go, the more critical your contact patches become. Fast race drivers are masters of weight management. They shift weight smoothly and seamlessly from front to rear, from side to side in an effort to maximize traction and maintain speed around the track.
Great weight management requires an empathetic connection to a car's suspension and those tiny little tire contact patches. Smooth braking. Smooth throttle. Smooth weight transition while at speed. Balance. Touch. Feel. This is what separates the great drivers from the near-greats.
Once you have read all of the books on race driving and after you have learned all of the proper driving techniques, racing ultimately comes down to a couple of factors: How well you are communicating with your race car and how much in synch you are with the race track. Hopefully, at some point in time you will be able to concentrate less on the minute details of driving and start feeling like an artist who grows more confident with every bold brush stroke he puts down on canvas.
Tim Sharp has raced nearly everything, from Showroom Stock Porsches and FIA turbocharged Toyotas to Formula Vees and Trans-Am cars. Tim has driven for factory teams like Volkswagen, Porsche, TRD USA, TOMs/Toyota, Ralt and Autodynamics. He has 10 road racing series titles to his credit. He has also served as an instructor for the Bob Bondurant and
    Naposledy upravil(a) 935Baby dne 25.02.2007, 22:29, celkem upraveno 2 x.
    stiloman
    Příspěvek od stiloman » 25.02.2007, 22:14
    Většina článků, které my máme vystupovala v GRM's "Závodit s řemeslem " sloupce poslední málo roků bylo evoluční v skutečnosti. Začít více základními řidičskými zručnostma, my jsme postupovali rychle k více a více pokročilé techniky. Zatímco toto může pracovali dobře pro ty vás kdo být zkušení konkurenti a dlouhou dobu předplatitelé, to není tak prospěšné novým čtenářům.
    Čas od času, to je důležité, že my se vrátíme k základním hnacím technikám a adrese nejvíce obyčejné základní řízení splete si. Tento článek není pouze pro výhodu nových čtenářů, ale pro nějakého čtenáře, který zaráží soutěž nebo při rychlosti. Po všech, dobré pokročilé řidičské zručnosti jsou stavěl na pevném základě dobrých základních řídících technik. Dokonce jestliže vy jste už dovedný soutěžní řidič, já jsem jistý vy budete se učit něčemu se hodnotou jako my zkoumáme vrchol 10 základních řídících chyb a jak opravit je.
    Definice termínů
    Dříve než my mluvíme o nejvíce obyčejných řídících chybách, my potřebujeme definovat podmínky, které my odkážeme použití v tomto článku. Zatímco následující podmínky platí více specificky k obvodům silničního závodu, většina také mít závažnost k autocross závodit s. (Poznámka k autocrossers: Vy můžete přát si vložit slova "kužel ukazatele " nebo "položit kužel " kde já používám slovo "kužel, " od autocross kursy jsou často lemované se stovkami sólových kuželů.)
    Závodit s linkou: Závodní linka je nejrychlejší způsob kolem dráhy když žádný provoz závodu je dar. U závodních škol, série kuželů jsou umístěny kolem dráhy učit studenty ideální závodní linka. Tím, že spojí tečky mezi těmito kuželi, vy budete nacházet si nejrychlejší cestu kolem dráhy. (Vidět ilustraci u správně: Linka přes rostoucí poloměrový roh.)
    Brzdit indikátory: Brzdící indikátory jsou obecně označené s čísly sestupování takový jako 4, 3, 2, 1. Tito jsou odkazy, které říkají řidiče když začít brzdit a downshifting předtím než vstoupí do rohu.
    Obrat v bodu: Odevzdat (nebo odmítat) kužele jsou tečky na vnější straně stopy které říci řidiče, "Toto je když vy byste měli začít se změnit na špici rohu." U tohoto bodu, který vy začnete oblouk vašeho rohu.
    Stopovat brzdění: Cestové brzdění je technika používajícího světla a postupně klesající brzdový tlak pomoci řídit vaše auto ke špici rohu. Používaný po brzdění přímé linky.
    Bod špice: Kužele špice označí vnitřní bod nebo geometrický střed rohu. Časná špice kužel obecně ukazuje zvětšující se poloměrový roh nebo roh, který rozšíří se u východu otočení. Pozdní špice kužel obecně ukazuje snižující se poloměrový roh nebo roh, který dostane těsnější k východu.
    Sledovat vnější bod: Dráha vnější kužele označí vnější tečku nebo extrémní vnější koncový bod rohu jako vy se oddělit od špice. Tyto kužele jsou lokalizovány na vnější straně rohu, a oni často předcházejí hned.
    Opravit linku: Tím, že udeří do vaší brzdy a downshift ukazuje vhodně a tím, že spojí tečky z obratu v kuželi k kuželi špice k dráze vnější kužel, vy máte správnou linku přes roh a na hned. (Vidět dole ilustraci). Poznámka: Zatímco většina SCCA závodních dráh bude mít ukazovatele brzdy, málo stop bude mít obrat v kuželích, kužele špice nebo dráhu vnější kužele. Vy jste očekáváni najít tyto body pro sebe. Odkaz k "kužele " v tomto článek je prostě používán usnadnit ilustraci pořádné linky.
    Understeer: Jestliže vy pokračujete v k číselníku ve více řízení se dostat do špice rohu ale vašeho auta nereaguje a jen jde rovně, toto je understeer. Understeer je také volán "tlak " nebo "pluh."
    Oversteer: Jako vy se změnit na špici rohu, jestliže základní konec vašeho auta začne se zlomit volný a cestovat rychleji než přední konec vašeho auta jako vy za rohem, toto je oversteer. V oválných stopových závodních kruhách, oversteer je také znán jako "vyjít ven " nebo "upustit podmínku."
    Nejlepších 10 základních řídících chyb:
    Splést si #1: Nesprávná řídící pozice
    Pořádné řízení pozice je důležitá protože to pomůže vám dostat optimální odezvu od šasi vašeho auta zatímco také chrání vás před dobýváním unavený.
    Nejprve, vaše místo by mělo být nastaveno aby vy jste schopní stlačit hnízdo úplně a vykonávat patu/brzdění prstu bez prásknout vašimi koleny na sloupku řízení. Vy byste měli také být schopní používat mrtvý pedál pro podporu přes high-g se otočí. Vaše rameno spojit should být těsný aby vy nepotřebujete se spoléhat na volant pro podporu.
    Další, vy byste měli mít 90- k 120-degree míry se ohýbá v vašich loktech s vašimi rukama ve správný 3 a 9 hodin pozice na volantu. Toto dovolí vám dělat 180-degree míry se otočí kola když vy potřebujete opravit oversteer klouzat.
    Ideálně, vaše palce by měly být v styku s 3 a 9 špicí na volantu. Toto dá vám více přímé zpětné vazby od předního zastavení v případě understeer situace. (Poznámka: Od auta rovnice a závodníka sportů volanty jsou menší ve průměru, vaše zbraně by měly být rovnější a mít méně ohnout u loktů).
    Nakonec, váš zadek by měl být dán pevně do opěradla sedadla aby vy můžete dostat odezvu ze šasi a nahoru přes místo. Toto dá vám lepší pocit pokud jde o co základní konec auta dělá. V udržování se Zen filozofií proběhnutí, vy byste měli se stát jedním s vaším autem. Dostat klidný, jít rychleji.
    Splést si #2: Opomenutí vypadat jako Ahead
    Nejvíce obyčejná řídící chyba v obou autocross a proběhnutí silnice je neschopnost podívat se daleko dost vpřed.
    Jako řidiči ulice, mnoho z nás stát se lenivý a dívat se jen mezi pilíře (ti srážejí dolů pošty, které hraničí s okraji našeho čelního skla). Na závodní dráze, kvůli plánování a zahrnutým vysokým rychlostem, toto nenajde si práci hotový. Vy musíte připravit sebe ne jen aby podíval se hodně dále vpřed, ale ven levá a pravá postranní okna také.
    Vstoupit do rohu, jako vy dělají vaše brzdění a downshifting, vy musíte být dívající se dopředu ke špici rohu. Dříve než vy se dostanete ke špici, vy byste měli být dívající se dopředu k vaší dráze vnější bod. V "S " otočí, často vy musíte být dívající se dopředu k druhé špici, spíše než roh vy jste v. V tomto případě, vy musíte spoléhat na váš periferní zrak se starat o první špici.
    Orientační pravidlo je, "Rychlejší auto, dále vy musíte dívat se vpřed." Choroba "odehnat váš kryt " je jeden to odsoudí mnoho řidičů závodu k pomalejším autům zatímco ostatní konkurenti udělají přechod k vyšším poháněným autům bez námahy.
    Jestliže vy jste omezení v podmínkách dráhového času, cvičit podívat se hodně dále dopředu a vnější postranní okna jako vy prodávají mimo rampy a rohy na zádech silnice. Jestliže se dívá dopředu stává se obvyklý, vy mnohem více pravděpodobně použijete techniku na závodní dráze. A ne, já nejsem obhajovat, že vy nastavíte vaši uliční rychlost ražení nahoru vyrovnat se vaší znovu nalezené, dalekonosné vizi. Ten lístek je na vás.
    Splést si #3: Nesprávná brzdící technika
    Jestliže vy často brzdíte příliš brzy pro roh, vy můžete najít to se dívat dopředu vyřeší váš problém. Když vy víte kde špice a sledovat vnější body jsou lokalizovány, to je hodně snadnější vědět to když zmírnit pedál brzdy a přesně jak hodně vydat to. Nicméně, vy můžete mít jiné problémy brzdění, které nezmizí tak snadno.
    Někteří řidiči brzdí těžko dost v přímce zpomalit jejich auto pro roh, ale pak oni totálně uvolnit brzdu nebo jít do plynového pedálu dříve než oni dostanou se do špice rohu. Oni přemístí hmotnost mimo přední pneumatiky a na zadních kolech jen když oni potřebují jejich řízení nejvíce. Toto může přimět auto, aby šel do understeer smyk. (Předložit znovu k ilustraci na dolní části protější stránky.)
    Aby ponechal si váhu na přední straně a pneumatiková kontaktní místa rozšířená pro optimální řízení, vy byste měli používat brzdění cesty. Cestové brzdění prostě pokračuje aplikovat zmenšující se procento brzdění až do vás dokončit vaše otočení do špice. Přechod od brzdění cesty ke špici a použití plynového pedálu k dráze vnější bod by měl být hladký a hladký tak jako nerozrušit šasi.
    Splést si #4: Nevhodná Downshift technika
    Více správně, toto by mělo být voláno "Nevhodná brzda a Downshift technika, " protože to je obtížné oddělit dva. Já bych rád vysvětlil celý sled heel-and-toe brzdění a downshifting; to by byl článek v sobě, nicméně, tak já chci ne.
    Prostě dát, teorie heel-and-toe downshift je toto: Když brzdí a downshifting před rohem, vy musíte brzdit v přímce zatímco současně svírá auto, túrovat motor vyrovnat se rychlosti hnacích kol, dát auto do nižšího rychlostního stupně a pak uvolnění hnízdo bez rozrušit pneumatiková kontaktní místa a zastavení v procesu.
    Pro ty vás kdo neznají jak k heel-and-toe downshift, vy můžete chtít jít do Boba Bonduranta nebo přeskočit Barber's autoškoly. Pro ty vás kdo vědět jak k heel-and-toe downshift, ale být ještě ne dělat to jak hladce jako vy by měl rád (i.e.: vy jste švitořící pneumatiky když vás downshift), tady být několik tipů:
    · S vaším autem v neutrální a s běžícím strojem, cvičit dát tlak na pedál brzdy s koulí vaší nohy zatímco houpá vaši patu a ven z vaší nohy přes na pedálu plynu. Prosím, se nedotýkají páky posunu!
    · Užít konstantní brzdový pedálový tlak, pokusit se roztočit stroj k rozumný rpm a držet to tam. Opakovat proces, se otáčet na vaší noze od zanechal správně do okamžiku než vy cítíte, že vy můžete dělat toto se shodný repeatability. Vaše pneumatika švitořící problém je pravděpodobně způsobený k vašemu nedostatku roztočit váš stroj vysoce dost nebo blurping plynový pedál a downshifting příliš pomalu.
    · Praxe vaše downshifts u váš příští autocross akce nebo na neobývaných vedlejších silnicích. Lepší zatím, vzít další záloze kurs autoškoly až do vás mít vaši patu/prst downshift dokonalý. Dobré brzdění a downshifting je základní jestliže vy chcete zlepšit vaše časy klína. (Ne každý, nicméně, je zaujatý dobrou patou/prstem downshift technika. Mr. Holland, můj řidič střední školy učitel vzdělání, odlišil mě pro dělat to.)
    Splést si #5: Apexing Too Early
    Na většině závodních dráhách, tam je mnohem více pozdní špice rohy než časná špice rohy. Tak, jestliže vy chcete být úspěšný v autocross nebo silniční proběhnutí, vy jste měli lépe dostat zvyklý na učení jak jezdit s pozdní špicí rohy. U autoškol, kde kužele označí obrat v bodech, špice a dráhu vnější body, vy nemůžete mít problém. Ale co okolo řídit neznámou dráhu? Pro větší pochopení tohoto problému, prosím se odkazovat na ilustraci pod.
    Špice pro roh je snadný způsob, jak určit umístění. Práce zpět od dráhy vnější bod, ke špici, pak k obratu v bodě. Ideálně, vy chcete vystoupit z rohu v jako rovný linka jako možný. Toto pomůže vám udržovat hybnost a maximalizovat hned rychlost.
    Když jedná se víc než jedním rohem (Vidět dole ilustraci), kde poslední koutek v sérii vede na dlouho hned, vy musíte často obětovat vaši rychlost vstupu do prvního rohu dostat více rychlosti konce pryč posledního rohu. To je lepší k "zajít zpomalovat a vycházet rychle " když vystoupí na rovný.
    Apexing příliš brzy je číslo jeden zabiják hned hybnost. Symptomy apexing příliš brzy být jak následuje: Vy se změníte na roh kde vy myslíte špice by měla být, ale na vystoupit z rohu, vy shledáte, že vy potřebujete přílišný řídící vstup spravedlivý k pobytu na dráze. Vy máte majora understeer a vy jste odírání mimo cestu příliš mnoho rychlosti u dráhy vnější bod jako vy vystoupit z rohu. Vracet se a studovat řada této části dráhy znovu. Vy můžete být apexing příliš brzy.
    Splést si #6: Předčasné zrychlení
    Jestliže vy nejste apexing příliš brzy, vy můžete trpí předčasným zrychlením. Zatímco rozpačité, předčasné zrychlení není podmínka, kterou vy máte žít se navždy. Nicméně, lék přece vyžaduje trpělivost a kontrolu.
    To není dost k brzdě a downshift vhodně a změnit se na špici u pravého bodu jestliže vy stále budete aplikovat plynový pedál příliš brzy v rohu. Být trpělivý. Brzda cesty dlouhý dost dostat nos vašeho auta ukázal na špici a se ztotožnil s vaší dráhou vnější bod. Proč vyrazit předtím vy máte auto zaměřené ve správném směru? Když vás přechod k plynovému pedálu, dělat tak hladce bez rozrušit šasi, ale být připravený jít do plynového pedálu když vy dostanete se k vaší poslední špici a autu je zaměřen dole rovně.
    Splést si #7: Ne používat celou dráhu
    Jestliže vy díváte se na profesionální F1 řidiče, vy všimnete si, že oni používají každý poslední palec závodní dráhy, včetně plochých omezení. Všichni příliš často já následuji studenty, kteří mají velkou techniku ale kdo nepoužívají celou závodní dráhu. Toto zraní jejich časy klína hrozně. Když žádal o, "Proč nejsou vás používat celou dráhu?" oni obvykle odpovídají s překvapením, "Já jsem myslel si, že já jsem byl."
    U nějakého času během praxe, vy byste měli se dotýkat omezení mírně aby vy víte, že vy používáte celou dráhu. Další, vy byste měli zjistit kterého bytu omezení budou pomáhat nebo bolet vaše časy klína. Proběhnutí je hra inches. Inches stává se tenths sekundu. Tenth sekundy na každém roh může změnit se na plnou sekundu na klín.
    Splést si #8: Opomenutí kompenzovat úhly spodničky
    Každý ví, že závodní auta kloužou nebo driftují v zatáčkách, ale ne všichni řidiči závodu kompletně rozumějí účinkům úhlů spodničky nebo směru posunu.
    Jestliže vy jste brzdění, downshifting a změnit se na roh správně, ale být ještě ne se blížit ke špici, vy nemůžete vynahradí spodničkový úhel vašeho auta. Snad vy usilujete na kužel špice, ale vy jen nemůžete vypadat, že udeří do toho správně.
    Oprava může být relativně snadná. Cíl za kužel špice, představit si "falešný " nebo "přízrak " kužel špice je tam. Tím, že vynahradí spodničkový úhel vašeho auta, vy chcete pravděpodobně udeřil do špice přesně. Toto může vzít některé experimentování jako vy může nahradit příliš mnoho nebo příliš málo pro úhel spodničky zatímco najde vaši domnělou špici.
    Splést si #9: Zabít vaši hybnost v provozu
    Zatímco tato chyba řízení nevztahuje se na autocross závodit se, to je nejvíce rozhodně jedno většina obyčejných a frustrujících problémů pro nezkušené závodní řidiče. Získávání vtěsnalo do. Ztrácet na vaší síle. Získávání lepilo se za pomalejší auto. Být neschopný vypadat jako klín nebo dva. Toto zní známě?
    Nejlepší řešení tohoto problému je časné rozpoznání pomalejšího řidiče. Všimnout si kde on je na dráze nyní a kde on většina pravděpodobné vůle je když vy chcete projít kolem něj. V závislosti na vaší rychlosti závodu, vy můžete jedna potřeba zrychlit nebo zpomalit se projít kolem něj u bodu kde vaše hybnost nebude zmenšená dramaticky.
    Vy můžete mít k ruchu a vnější brzdě lapper před příští sérií se zpomalit "S " otočí, nebo vy můžete muset sklopit malý a stavět hybnost mimo pořadí předat jej další hned. Toto zdokonalí umění se dívat dopředu k maximální.
    Jestliže vy dostanete se extrémně schopný v této technice, vy můžete používat to ke strategicky vložit auto, kolem kterého vy projdete mezi vámi a auto, které je v horké snaze o vás. Ne jen moci se dívat dopředu být použitý udržovat vaši vlastní hybnost, ale to může být používáno zabít někoho jiný hybnost. Když to pracuje, to je opravdu krásná věc.
    Splést si #10: Chudé váhové vedení
    Malá pneumatiková kontaktní místa jsou všichni ti držet vás od opustit dráhu. Rychlejší vy jdete, více kritický vaše kontaktní místa stávají se. Řidiči rychlého závodu jsou mistři vedení váhy. Oni přemístí hmotnost hladce a hladce od přední strany chovat, od strany strany ve snaze maximalizovat tah a udržovat rychlost kolem dráhy.
    Vedení velké váhy vyžaduje empatické spojení se zastavením auta a ty malá malá pneumatiková kontaktní místa. Hladké brzdění. Smooth škrtí. Smooth zatěžuje chvíli přechodu při rychlosti. Vyrovnat. Dotek. Pocit. Toto je co odděluje velké ovladače od blízkých velikánů.
    Jednou vy jste četli všechny knih o řízení závodu a poté co vy jste se učili všem pořádného řízení techniky, proběhnutí nakonec dosahuje po pár faktorů: Jak dobře vy komunikujete s vaším autem závodu a jak hodně v synch vy jste se závodní dráhou. Nadějně, u nějakého důvodu k času vy budete schopné soustředit se méně na drobných detailech řízení a začátku se cítit jako umělec, který stane se více jistý s každým tučným tahem štětcem, který on položí na plachtovině.
    Tim Sharp hnal se téměř všechno, od akcií předváděcí místnosti Porsches a FIA turbocharged Toyotas k rovnici Vees a Trans-Am auta. Tim razil pro tovární týmy jako Volkswagen, Porsche, TRD USA, TOMs/Toyota, Ralt a Autodynamics. On má 10 silnice závodit se sériovými nároky na jeho úvěr. On také sloužil jako instruktor pro Boba Bonduranta a
    935Baby
    Příspěvek od 935Baby » 25.02.2007, 22:20
    Sakra, takovej rychlej preklad. Dik ze jsi to prelozil pro ostatni :)
    Update:
    Jsem cetl par casti, dobrej pokus o preklad ale relozilo to uplne picoviny :lol:
    Priklad:
    preloženo
    Opomenutí kompenzovat úhly spodničky :lol: :lol: :lol:
    masakr
    Naposledy upravil(a) 935Baby dne 25.02.2007, 22:24, celkem upraveno 2 x.
    stiloman
    Příspěvek od stiloman » 25.02.2007, 22:21
    já ne.....Eurotran 2003 :-D
    doublejay
    Příspěvek od doublejay » 25.02.2007, 22:22
    ten automatický překlad je totální katastrofa... anglicky tomu rozumím, tomu překladu ani zblo.
    Příspěvek od Martin_534 » 25.02.2007, 22:29
    dobrej překlad :-D
    stiloman
    Příspěvek od stiloman » 25.02.2007, 22:29
    překlad byl pro takový lopaty jako jáá :-D
    Peca
    Příspěvek od Peca » 25.02.2007, 22:36
    Jakozto obcasneho prekladatele me z toho malem jeblo :lol:
    Příspěvek od Kentoya » 26.02.2007, 07:45
    tak to občasný překladateli přelož
    Peca
    Příspěvek od Peca » 26.02.2007, 08:34
    Ze bych to prelozil? Bylo by kdyztak vic zajemcu?
    Goodziller
    Příspěvek od Goodziller » 26.02.2007, 08:41
    Ja tomu nerozumim ani anglicky ani tomu prekladu....
    tomita
    Příspěvek od tomita » 26.02.2007, 08:44
    Ja tomu rozumim i po anglicky, ale kdo to ma cist... :roll:
    Příspěvek od kenivruh » 26.02.2007, 10:01
    Tak ten "trail braking" som robil v Brne a ani som nevedel, ze je o tom aj nejaka teoria 8)
    adner
    Příspěvek od adner » 26.02.2007, 10:31
    o technice závodní jízdy je teorie jak nas.áno akorát ne v čr
    sic
    Příspěvek od sic » 27.02.2007, 09:44
    a opat som mudrejsi :smt098
    Uživatelé prohlížející si toto fórum: Žádní registrovaní uživatelé a 155 hostů
