Motor Chevy 454 7.4 V8 novy. Bez toho sani na fotce, to je pro kompresor. Vykon 500hp pri pouziti 800cfm karbce. Je moznost koupit i sani pro EFI. Spodek je stavenej na 1000hp, takze pri pouziti nejvetsiho kompresoru od Weiandu bude vykon kolem 750-800hp. Vice na email ci tel.
sejkoramartin@gmail.com
777704145
-DART BIG M 454 aftermarket engine block - NEW
-HP cast iron heads - OEM heads with a new angle job done
-MANLEY stainless steel valves - NEW
-COMP CAM springs - NEW + ARP studs - NEW
-SCORPION 1.7 rockers - NEW
-ARP head studs -NEW
-Aluminum valve covers – NEW - modified
-EAGLE rotating assembly ( forged pistons, H beam connecting rods, forged steel crank ) - NEW
-ARP main bolts ) - NEW
-LUNATI hydraulic roller cam 50249LUN - NEW
-COMP CAM hydraulic lifters - NEW
-COMP CAM push rods - NEW
-HORSCHEL fluid damper - NEW
-PETE JACKSON timing gear drive - NEW
-Aluminum timing cover - NEW
-EDELBROCK aluminum water pump with aluminum pulley - NEW
-MARCH PERFORMANCE aluminum steering pump with aluminum pulley + stainless bracket - NEW
-High volume oil pump - NEW
-MILODON oil pan - NEW
-MSD distributer - NEW
-SUMMIT small starter up to 16 : 1 compression ratio - NEW
-FEL PRO gaskets set for whole engine and in addition a pair of soft coper head gaskets - NEW
-Hooker Headers, modified to fit corvette chassis - NEW
![Obrázek](http://img836.imageshack.us/img836/6929/fotografie0174.jpg)
