Fatal error: Uncaught Error: mysqli object is not fully initialized in C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\phpbb\db\driver\mysqli.php:200
Stack trace:
#0 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\phpbb\db\driver\mysqli.php(200): mysqli_query(Object(mysqli), 'SELECT config_n...')
#1 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\phpbb\db\driver\factory.php(345): phpbb\db\driver\mysqli->sql_query('SELECT config_n...', 0)
#2 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\phpbb\config\db.php(72): phpbb\db\driver\factory->sql_query('SELECT config_n...')
#3 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\phpbb\config\db.php(55): phpbb\config\db->initialise(Object(phpbb\cache\driver\file))
#4 [internal function]: phpbb\config\db->__construct(Object(phpbb\db\driver\factory), Object(phpbb\cache\driver\file), 'phpbb_config')
#5 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\vendor\symfony\dependency-injection\ContainerBuilder.php(1176): ReflectionClass->newInstanceArgs(Array)
#6 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\vendor\symfony\dependency-injection\ContainerBuilder.php(634): Symfony\Component\DependencyInjection\ContainerBuilder->createService(Object(Symfony\Component\DependencyInjection\Definition), Array, true, 'config')
#7 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\vendor\symfony\dependency-injection\ContainerBuilder.php(1281): Symfony\Component\DependencyInjection\ContainerBuilder->doGet('config', 1, Array, true)
#8 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\vendor\symfony\dependency-injection\ContainerBuilder.php(1238): Symfony\Component\DependencyInjection\ContainerBuilder->doResolveServices(Object(Symfony\Component\DependencyInjection\Reference), Array, true)
#9 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\vendor\symfony\dependency-injection\ContainerBuilder.php(1149): Symfony\Component\DependencyInjection\ContainerBuilder->doResolveServices(Array, Array, true)
#10 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\vendor\symfony\dependency-injection\ContainerBuilder.php(634): Symfony\Component\DependencyInjection\ContainerBuilder->createService(Object(Symfony\Component\DependencyInjection\Definition), Array, true, 'cache')
#11 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\vendor\symfony\dependency-injection\ContainerBuilder.php(588): Symfony\Component\DependencyInjection\ContainerBuilder->doGet('cache', 1)
#12 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\includes\compatibility_globals.php(45): Symfony\Component\DependencyInjection\ContainerBuilder->get('cache')
#13 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\common.php(139): register_compatibility_globals()
#14 C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\viewtopic.php(20): include('C:\\Program File...')
#15 {main}
thrown in C:\Program Files (x86)\EasyPHP-DevServer-13.1VC11\data\localweb\projects\200sx\phpbb\db\driver\mysqli.php on line 200
