P: Raritni T25g turbo - PRODANO
Zemi RHD-cars
Příspěvek od Zemi RHD-cars »
Laicky kdo nezna t25g - saci housing T25 / vyfukovy housing T28 .86
Stav OK - plne funkcni... Minimalni axial. vule.
FOTO >>> http://rhd-cars.rajce.idnes.cz/t25g/
Cena 6000,- >>> 5500,- >>> 5000,-
608372848
Naposledy upravil(a) Zemi RHD-cars dne 06.08.2010, 08:32, celkem upraveno 3 x.
tel. 608 372 848
Re: P: Raritni T25g turbo z JDM SR20DET
Příspěvek od kenivruh »
Sorry ze leziem do zaberu, ale vie mi niekto povedat vyhodu tohto turba voci T25?
Zemi RHD-cars
The T25G is the next generation T25 that came out on the SR20DET S13 cars.
The only difference is a larger Exhaust housing and fins allowing slightly more boost to be held at top end with a lil less inlet temps.
If you can pick 1 up cheap, go for it! its a quick easy upgrade, but still wont be to fantastic over 15psi just like the normal T25.
On a standard DET with stock ECU, injectors etc, this turbo will be enough to net you around 230-250bhp@14psi
tel. 608 372 848
Zemi RHD-cars
Slevicka
tel. 608 372 848
Zemi RHD-cars
tel. 608 372 848
Zemi RHD-cars
OMG ani za bura?
tel. 608 372 848
kourilo?? a jak bude pasovat na svody a downpipe z T25?
Zemi RHD-cars
Nekourilo a plne funkcni jinak bych to napsal... Pasovat bude.... Je to T25 intake / T28 vyfuk... :wink:
tel. 608 372 848
ok dik hodim myslenku...
Zemi RHD-cars
Ty voe. :shock: :roll:
tel. 608 372 848
kdyz vydrzi jeste cca 10 dnu tak ho vezmu... proste jak mi dojde vyplata :D ta mrcha co mam v aute zacala po 25km celkem kourit... :(
Zemi RHD-cars
Fizzbiker píše:kdyz vydrzi jeste cca 10 dnu tak ho vezmu... proste jak mi dojde vyplata :D ta mrcha co mam v aute zacala po 25km celkem kourit... :(
Po 25km? Co to bylo zac? Jinak koukam v SZ ze to ani 10dni nebude. :)
tel. 608 372 848
no dle prodejce motoru melo byt v super stavu... podle me je super stav trochu neco jineho... jo no su trochu nasranej protoze budu asi zase sundavat prevodovku (hadam tak po 11cty) tak ze bych to sfoukl naraz ze tam jako bude vic mista ale dost mozna pujde na policku a tuhle fenu proste dorazim... a turbo pujde az na novy motor. uvidim...
Naposledy upravil(a) Fizzbiker dne 06.08.2010, 08:51, celkem upraveno 1 x.
Zemi RHD-cars
Aha cesti prodejci... :roll: OK takze prodano... :!:
tel. 608 372 848
