Ma na sobe pridelanou matku pro snadne povoleni
Zpetny ventil ktery zabranuje vytekani oleje z filtru po delsim stani auta.
Pry super filtraci
Co si o nem myslite?
- vyplati se dat tolik za filtr?
Na www.riegger.cz ha maji v eshopu za 547Kč (je to sice pro S14, pro S13 tam v nabidce nemaji. Ale urcite to bude pasovat i na S13)
http://www.knfilters.com/search/product ... od=HP-1008
Osobne bych co se tyce oleje a filtru dal autu to nejlepsi co muzu. Olej davam Castrol Magnatec 10W-40 (ja vim 10W-60 je nejlepsi, ale nejezdim nejake zavody na okruhu) Filtr zatim pouzivam Champion.
Na sxoc.co.uk je take clanek o tom filtru, nic moc se tam o nich nepise ale zajimavy je tento prispevek:
____________________
Fitted a new nissan filter the other week - always used Nissan ones
I noticed (on my pressure gauge) the oil pressure taking longer than usual to build up on start up when the car had been left overnight etc
So I changed that filter for another Identical Nissan one and its back to normal now - I suspect the poor one had a dodgy cut off valve fitted and the oil was draining out of the filter more than it should have done
So be careful the Nissan ones may not always be as good as you think :no
___________________
Strucny preklad:
Pry nekdo kdo namontoval filtr od Nissanu a pred tim mel take od Nissanu, vsiml si ze u toho noveho trvalo po startu dele naz cerpadlo natlakovalo.
___________________
Ty same priznaky mam ja. Takze se me velice libi to ze ten filtr KN ma zeptny ventil. Zase jak pisou v tom clanku na sxoc je otazka zda je tento filtr vhodny pro normalni jezdeni kdy se olej meni po dlesich intervalech nez pri zavodeni na ktere je staveny.
