- MOTOR SE ZA STUDENA NECHCE NECHAT VYTOČIT Z VOLNOBĚŽNÝCH OTÁČEK...ZAKLEPE SE A PAK SE VYTOČÍ (TÍM NEMYSLÍM DO NĚJAKÝCH ZÁVRATNÝCH HODNOT ALE TŘEBA JEN DO 2000 OTÁČEK - PŘIPOMÍNÁM ŽE MÁM GO CELÉHO SPODKU A PŘEJETOU HLAVU)..ZA TÍM JSEM NEZJISTIL PROČ
- NĚCO MI TAM DŘE A POSLECHEM NA RAMPĚ JSEM DNES ZJISTIL ŽE TO JDE OD PŘEDĚLU MOTOR PŘEVODOVKA...NEJVÍCE JE TO SLŠET NA PLECHU CO KRYJE CELÝ ZADEK MOTORU....TZN ASI JSME HO TROCHU ZOHLI A DŘE O SETRVÁK...PORADÍ MI NĚKDO JAK JE PRACNÉ ODPOJIT PŘEVODOVKU A JAK NA TO? ASI BYCH HO MĚL VYMĚNIT A NEBO OPRAVIT.
- PO DOJEZDU MI BUBLÁ VODA.ALE NEVAŘÍ SE TO.NAJEL JSEM UŽ ASI 40KM TAK BY SE TO MOHLO ODVZDUŠNIT ASI UŽ.ASI NEJVÍCE TO JDE Z TOPENÍ.
DÍKY ZA RADY A MOC DÍKY ZA POMOC KATANYMU!
