Trochu projekt
Engine Head
HYPERTUNE 77mm TB
CUSTOM intake plenum
TOMEI 270 cams / Solid conversion IN & EX
TOMEI IN & EX cam gears
TOMEI Solid Pivot
TOMEI Shim clearance set
TOMEI gasket kit
TOMEI RAS
SUPERTECH double valve springs
SUPERTECH +1 oversized stainless intake valves (6mm stem)
SUPERTECH +1 oversized inconel exhaust valves (6mm stem)
SUPERTECH titanium valve retainers
SUPERTECH manganese/bronze valve guides
SUPERTECH Spring locators
SUPERTECH Valve seals
NAPREC rocker arms
NAPREC cam cap studs
NAPREC timing chain
ARP Custom half inch head bolts
ARP Stainless Intake and Exhaust Stud Kit
POWER ENTERPRISES 90mm head gasket
Ported and polished head
Engine Block
TOMEI Billet Crank 91mm stroke
GREDDY / TRUST H beam conrods made by Carrillo with CARR bolts
CP 90mm pistons with anti-det grooves, skirt coating, double pin oiler & tungsten pins
ACL Race Series Bearings, crank end, main and conrods
ARP main bolts
DARTON cylinder sleeves
CNC billet crank girdle
ROSSTUFFBOND harmonic balancer
S15 Oil Pump
JUN Water Pump
Engine Accessories
TRUST / GREDDY Type R blow off valve
TRUST / GREDDY AirInx Pod filter
TRUST / GREDDY Oil cap
TRUST / GREDDY Sump
TRUST / GReddy pulley kit
NISMO engine & transition mounts
CUSCO Oil catch tank
SARD silicone boost lines
SAMCO silicone rad hoses
EMBLETON overflow tank
BILLION Power Steering tank
BILLION Cold air intake
BILLION silicone coolant lines
BLITZ silicone top radiator hose
POWER ENTERPRISE Belts
PIVOT Raizin volt stabiliser
SPEEDFLOW SS lines and fittings
SUNLINE RACING oil filter relocation kit
JMOTORSPORT CAS cover
Ignition
SPLITFIRE Direct Ignition system
HKS Twin Power Type-DLI
NGK Iridium plugs
Drivetrain
EXEDY hyper twin-plate clutch and flywheel
NISMO LSD 2 way 4.1
NISMO Release Pivot
NISMO Slave cylinder
NISMO Release bearing and sleeve
SPEEDFLOW #3 Clutch line
Nissan NEW CMS
Nissan VG30 turbo transmission
Nissan BNR2 Differential and half shafts
MAZWORKS bellhousing adapter plate
MAZWORKS 1 piece prop shaft
MAZWORKS quick shifter
Induction
GARRETT GT3540 0.82
6BOOST steam pipe exhaust manifold
HKS GT II 50mm wastegate
HKS Turbo heat shield
GENIE Front pipe
MAGNAFLOW high flow cat
TRUST cat back exhaust
Fuel System
HKS Billet Fuel Rail custom duel entry
HKS 1000cc Injectors
SARD #6 Fuel Pressure Regulator
SARD Fuel Pressure Gage
BOSCH 044 external fuel pumps x2
TOMEI Intank fuel pump
KRC fuel filters x2
GOGEAR surge tank fuel
SPEEDFLOW #6 Teflon braided lines
Cooling
TRUST / GREDDY Oil cooler
TRUST / GREDDY VSP-L front mount intercooler
TRUST / GREDDY airbreather tank
TRUST Air diversion plate
KOYO 3 layer copper radiator
DAVIS CRAIG 12″ thermos x 2
ARC Thermostat
EARKS Power Steering cooler and tefton lines
Electronics
APEXI Power FC D-Jetro
TRUST Profec B spec II boost controller
Blitz turbo timer
Suspension & Handling
TEIN type HR coil over suspension
TEIN tie rods
TEIN tie rod ends
KAZAMA Hicus lock bar
KAZAMA Alloy subframe bushes
SUNLINE RACING solid diff bushes
IKEYA Formula front roll centre aduster arms
D-PROJECT Rear Upper Arms
D-PROJECTt Traction Rods
CUSCO 7 point safety 21 cage
CUSCO front and rear strut brace
CUSCO Master Brake Cylinder Stopper
EARLS brakeline fittings
NISMO Front Power brace
BREMBO GTR33 Calipers front & rear
PROJECT MU SCR Pro rotors front
PROJECT MU SCR rotors rear
PROJECT MU Type NR Brake pads front and back
PROJECT MU Inner shoes
PROJECT MU Brakelines rear
NAGISA AUTO Strut supports
NISSAN GTR32 Non ABS BMC
NISMO Steering Rack bushes
SUNLINE RACING Steering Rod bush
WHITELINE GTR32 rear sway and S13 Front adjustable
Interior
RAZO race pedals
PIVOT Stepping boost, oil temp, water temp
PIVOT shiftlight
3 pod dash gauge holder
OMP Kill switch
WORKS BELL Quick release
MOMO ‘course’ steering wheel
MOMO Compition shift knob
MOMO gear boot
BRIDE BRIX II seats
BRIDE Seat Rails
BRIDE Floor mats
TAKATA Harness x 2
D-MAX Carbon Doors
CYBERSTORK white dials
CUSCO E-brake Drift button
Exterior
BOMEX Carbon Aero side mirrors
MSPORTS Carbon Diffuser
MSPORTS FRP Bonnet
MSPORTS kit - type B front bar, skirts, rear bumper and front fenders
SUPERMADE Headlight Conversion
URAS Flasher Kit
D-STYLE smoked side indicators
VOLK GT-N 18×9+25 and 18×10+25
NISMO wheel studs
RAYS wheel nuts
POTENZA Tyres RE01
TOPSECRET Areocatch pins
Type X Kouki Taillights
C-WEST Smoked Taillight Covers
OMP Tow Hooks
Features
Full respray
Battery relocation
Sound deadening removed
Flocked dash
Engine loom hidden
Flared 25mm rear guards
Comming soon
Do-luck cross bar ladder bar front and rear
Ikeya Formula rear lower control arms
Driftworks HICAS removal kit(replace factory toe)
OS Giken 1-5 transmission with input and layshaft for Z32
HPI Acrylic windows
WILWOOD Brake Bios adjuster
Uras chasis brace
OST rear brace
Zenith rear boot brace
Cusco side entry bars
