prej "princip"
(pro english hovořící)
The Neo Socket is somewhat like a battery, it capacitors act like tiny storage batteries that charge and discharge rapidly. Made of two plates separated by a thin insulator or sometimes air, when one plate is charged negative and the other positive, a charge builds up and remains after the current is removed. When power is required, the circuit is switched to conduct current between the plates, and the charge is released, thus causing your vehicles electrical system to not work as hard which helps improve fuel economy, and helps make your vehicle last longer.
Současně Hyundai Scoupe 1.5T (k&n,ic, bov, vejfuk, podvozek dole, atd atd...)
Do budoucna snad SX
